N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
mike335i mike335i is offline
Tuner: JB2X
Default Does muffler delete loose torque/hp? - 12-01-2009, 07:26 PM
Has the title say, does somebody knows if doing a muffler delete, is the car going to loose power?
boostedcosta's Avatar
boostedcosta boostedcosta is offline
SUPERMAN
Tuner: jb3
Default 12-01-2009, 07:28 PM
no
Tuner: JB2X
Default 12-01-2009, 07:34 PM
thanks, but doest it gain so?
Car: 135i, 335i, X5D
Tuner: BMS
Default 12-01-2009, 07:35 PM
Why would it ever lose power? May not gain much though.
Tuner: JB2X
Default 12-01-2009, 07:42 PM
ha ok, well my real question is, better to keep stock exhaust or to do muffler delete?
Tuner: BMS
Default 12-01-2009, 08:05 PM
For sound do delete, for performance it doesn't matter.
Tuner: JB2X
Default 12-01-2009, 08:18 PM
ok thanks guys
Hit_Apex's Avatar
Hit_Apex Hit_Apex is offline
Riding the knock sensor
Car: 08.335i 06.M3
Tuner: T
Default 12-01-2009, 08:21 PM
The word is lose. Carry on.
Driver72 Driver72 is offline
Default 12-01-2009, 08:23 PM
When I was on my first tuned 335i, I got a PM from a guy in a stock 6MT car who wanted to see how his stock 6MT car would stack up against me in a tune only 6AT car. He lost of course.
Then he called me back 2 weeks later and wanted to meet up again after he removed his axle back (no mufflers and piping from last cat to mufflers.
His car was pretty loud then (you'd have to drive like a granny around ANY law enforcement officer, or when coming home late at night if you want to stay on your neighbors good side) but I did notice his car seemed to be a bit quicker.
We did not only runs from dig, but from various starting points.
I'd pull on him sooner when he was stock.
Without the mufflers he seemed to hold with me for the first split second, and seemed to fall back slower than he did when stock.
Keep in mind this was on the first tune of a 335i (313 whp) and trap speeds of 108-109 mph in best case scenarios.
I'd say in a 40-120 mph run, he stayed 1-1.25 Car lengths closer without the axle back on (but still lost by 3-4 CL's)
Two reasons, dropping 30-40 lbs probably helped and less back pressure must be worth 8-10 hp (heck catback exhaust seem to add 6-8 hp themselves, so having NO catback, has got to be worth a couple more than that too). Combined it was enough to keep him 1+ CL closer.
But to me, it wouldn't be worth the glares you'll get from other drivers, the ticket you'll eventually get from the po-po and the "what the heck did you do to that BMW" comments from other BMW drivers you'll surely get as well.
Stay stock or go with a nice sounding catback instead. Nearly the same power gain, 10-15 less pounds in weight or stock, and no glares, no laughs, no tickets.
