As promissed,
I tested my intake Saturday morning to see if the changes made improvements.
For those who don't want the excutive summary, the Mr. 5 Intake performed the best out of the DCI and the OEM air box.
For those who don't know, this was my original design:
http://www.e90post.com/forums/showth...3538&highlight
This is the updated version which I used during this test:
http://www.e90post.com/forums/showth...9293&highlight
Now before anyone starts to think that these results are scewed then think again. I'm not selling this. It was just an idea that I had (Thanks Dinan
) to grab the coldest air for the engine without the restrictions.
Also, I chose a road that goes slightly up hill so we don't have the "Those 60-100 runs are slow compared to what others are getting" posts. I also wanted to see how each intake did under pressure.
All off topic posts will be deleted since we are only talking about the comparisons of intakes.
This is what I did:
3 Runs with my Intake
3 runs with the OEM air box
3 runs with the DCI
2 runs with my intake again to make sure I wasn't seeing things.
I highlighted the best run of each.
Mr. 5 Intake
Time 4.63
Peak Boost 15.95
Average Boost 14.006
Average Wastegate Pulse Duration 45.28%
Peak Wastegate Pulse Duration 49.48%
Time 4.63
Peak Boost 15.95
Average Boost 14.08
Average Wastegate Pulse Duration 45.25%
Peak Wastegate Pulse Duration 49.43%
Time 4.66
Peak Boost 15.95
Average Boost 14.09
Average Wastegate Pulse Duration 44.88%
Peak Wastegate Pulse Duration 50.23%
Stock
Time 4.73
Peak Boost 16.095
Average Boost 14.031
Average Wastegate Pulse Duration 46.09%
Peak Wastegate Pulse Duration 52.88%
Time 4.68
Peak Boost 16.24
Average Boost 14.09
Average Wastegate Pulse Duration 49.09%
Peak Wastegate Pulse Duration 54.84%
Time 4.69
Peak Boost 16.385
Average Boost 14.10
Average Wastegate Pulse Duration 46.00%
Peak Wastegate Pulse Duration 53.91%
DCI
4.67
Peak Boost 16.24
Average Boost 14.33
Average Wastegate Pulse Duration 45.48%
Peak Wastegate Pulse Duration 50.54%
4.72
Peak Boost 16.24
Average Boost 14.34
Average Wastegate Pulse Duration 45.44%
Peak Wastegate Pulse Duration 51.42%
4.70
Sorry, but I forgot to hit the start button to log.
As you can see, the best times obtained were done with the Mr. 5 intake and the average boost, peak boost and wastegate duty cycles were less than with the other intakes.
When I finished the testing with the DCI, I was curious if it the conditions changed at all from when i ran the Mr. 5 intake earlier so I put it back on to see if I could replicate the results and I did.
I didn't do any BT logs but it's obvious that my intake did pretty well.
4.68 and 4.62 were the times when I put my intake back on so actually my best time was 4.62.
