Default 04-30-2017, 05:38 PM
Originally Posted by protecon
You shouldn't make methanol tanks out of aluminium.
Just because the tanks doesn't leak immediately, doesn't mean it isn't causing an issue. Stainless steel or vulcanised poly are the only safe options.
From a fabrication and welding company that specialises in aluminium;
You will need to anodize aluminum tanks, they are common in the industry when done correctly.
