codesx's Avatar
codesx codesx is offline
Default Meth and water, separation? - 09-01-2018, 03:48 PM
Hello friends,
Is there any issues with meth and water mixtures separating?
Think in summer when hot (trunk) and winter when sub 0.
Let's assume for arguments sake it's 50/50 and the car can sit up to 3 days.
I've not heard of people complaining, but not sure there are a lot of -25c users.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
mattgu40 mattgu40 is offline
Default 09-02-2018, 12:27 AM
i daily drive meth even in the winter pretty cold here in canuckistan, i make sure my mixture contain allot more meth to ensure it does not freeze in the plastic pipe.
protecon's Avatar
protecon protecon is offline
Car: 2010 X5M MCB
Default 09-02-2018, 12:37 AM
No because they're miscible substances.
The only reason your mix ratio will change once introduced, is by venting your tank to the atmosphere, leading to evaporation of the methanol.
Default 09-04-2018, 08:11 AM
Never had issues.
