Wrecker 426's Avatar
Wrecker 426 Wrecker 426 is offline
Car: 335xi
Default 335XI possible trans Issue, wont hold 2nd gear - 09-02-2018, 11:01 AM
My car will not hold 2nd gear when doing a boosted launch (if it is that on an auto) using JB4 anti-lag. gets about 15PSI and let it rip in 2nd gear makes about 30mph stutters and decides to shift to 3rd, and then the slow acceleration continues at 25 psi.
Is my trans on its way out?
would the xHP stage 3 be better?
didn't get any logs cause i was filming, fail on my part.
Video of 2 pulls
07' 335xi, VTT Stage 2 Turbos, Meth CM10, Stage 2 LPFP pri, walbro 525 LPFP 2nd, JB4 E85 BEF, VRSF exhaust, Phoenix Race IC, MMP AL inlets, VTT AL Outlet, PR Coils, BMP Intake w/750cc injectors, Manual swapped, SMF Spec Twin disk
soccerman1bmw soccerman1bmw is offline
Car: 2007 BMW 335i 4D
Default 09-02-2018, 11:41 AM
My mechanic says the valve body’s are what typically need replacing on these transmssions, putting xhp wont fix a mechanic issue
Car: 335xi
Default 09-02-2018, 12:00 PM
Originally Posted by soccerman1bmw
My mechanic says the valve bodyís are what typically need replacing on these transmssions, putting xhp wont fix a mechanic issue
Good to know.
Should also clarify itís only when I do a boosted leave from 0. Other wise it holds fine
