Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
Administrator
Car: M340i,X5,Raptor,C7 ZR1
Default New 2 gallon low profile meth tank - 04-28-2017, 08:01 PM
Pleased to announce the release of our new integrated universal water/meth tank. It's a once piece design with a mounting point for the pump and an integrated pump feed/baffle to ensure consistent performance. The low profile design makes it easy to fill and we have them in clear white for easy visual level checks or black for stealthier installations.
Tank dimensions: L 15.5" x W 8" x H 8.25"
More details here http://www.burgertuning.com/meth.html
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 04-28-2017, 08:42 PM
Nice!
Edit- is the tank baffled or sumped?
Mods: Stock for now
Default 04-28-2017, 09:08 PM
We've integrated a baffle in to the mold to allow operation at lower fluid levels.
PHAILUR PHAILUR is offline
Car: 335i n54
Default 04-28-2017, 10:41 PM
How safe is running meth. Any risk if you run out and your at WOT?
'09 e92 jet black 6sMT
VRSF Dp • VRSF Charge pipe• VRSF 7.5" intercooler• VRSF2" inlets• VRSF DCI•aFe intake scoops•HKS BOV•RB pcv valve•BMS Jb4 g5 w/ Bluetooth •BMS Oil catch can•BMS Clutch valve•NGK plugs•Bosch coils• 450lph Walbro for e85•Master Clutch lightened flywheel-ACT 6 puck clutch•turbo back straight pipe w/ all deleted
Default 04-29-2017, 06:18 AM
This is cool! I'd love one designed to fit in the under trunk compartment of the 1er.
N54 | Build Thread
Default 04-29-2017, 08:20 AM
With a JB4 controlling water/meth it's quite safe. We hold boost low until meth is flowing and drop boost if meth flow starts to drop, in addition to numerous other safety systems.
Default 04-29-2017, 08:22 AM
It costs around $30,000 to design the tanks, get the mold made, various 3D printed test articles, longer term testing, etc. So we can only do those for projected higher volume applications. The E82 doesn't make the cut for that, sorry. This tank does fit nicely in the E82 trunk space though pushed up against the rear seat.
NorCalN55 NorCalN55 is offline
Car: '11 335xi M Sport
Default 04-29-2017, 08:29 AM
I'm guessing the new billet vent caps will fit on this tank?!
Default 04-29-2017, 08:39 AM
Absolutely!
Administrator
Default 04-29-2017, 02:31 PM
Here it is with the billet cap.
Administrator
Default 04-29-2017, 04:06 PM
Lots of room around and above this tank. Perfect for many applications. 15.5" x 8" footprint.
Tin Tin is offline
Default 04-30-2017, 02:06 PM
That's a nice new tank, got the old 2.3gal version mounted in the same spot.
Custom tank made by some folks in Australia for 1Ms..
protecon's Avatar
protecon protecon is offline
Car: 2010 X5M MCB
Default 04-30-2017, 04:31 PM
You shouldn't make methanol tanks out of aluminium.
Just because the tanks doesn't leak immediately, doesn't mean it isn't causing an issue. Stainless steel or vulcanised poly are the only safe options.
From a fabrication and welding company that specialises in aluminium;
My experience is that Methanol will corrode aluminium unless you can maintain a clean surface after using, which in a tank I cannot see it being possible.
Lowon's Avatar
Car: Bmw M2
Default 04-30-2017, 05:13 PM
+1
Mods: Stock for now
Default 04-30-2017, 05:20 PM
Whew. Yeah, ok I get that. Too bad! Thanks for the reply Terry.
N54 | Build Thread
Default 04-30-2017, 05:38 PM
You will need to anodize aluminum tanks, they are common in the industry when done correctly.
Peter @ Pure's Avatar
Car: F20 M135i
Default 05-01-2017, 01:17 PM
Looking good. Will these replace the 2.3g tanks? Or both remain?
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
N54QC N54QC is offline
Car: 07 BMW 335i
Default 05-01-2017, 02:42 PM
I would hope not. I got the 2.3 and it tucks away nicely on the side of my trunk on my E90. If they were discontinuing those, I don't think I could part with mine knowing I would have to look for a used one should I ever sell my meth kit. IMO, 2.3 is the way to go with a E90 unless Terry comes up with something that can be put in underneath the trunk mat.
Default 05-01-2017, 02:47 PM
We haven't decided if we're going to keep the 2.3g 2piece tank around yet.
