Default Fuel-It! M5/S63TU development thread - 05-23-2016, 11:01 AM
Hey All,
We got in our new (to us) M5 and did some baseline testing while it's completely stock.
Name:  M5 photo.JPG
On the dyno last week and it did 464whp and 435wtq on 91 octane fuel.
Also still on 91 octane we did a few VBOX runs with it and it did a best of 5.67"s in our 40-90mph testing.
Now that's behind us we'll start upgrading so we can unlock the potential of this beast!
Peter @ Pure's Avatar
Car: F20 M135i
Default 05-23-2016, 11:11 AM
Looking forward to more upgrades and results from your cars!
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
ur20v ur20v is offline
Car: BMW F10 M5
Default 05-24-2016, 03:05 AM
Awesome- look forward to seeing what you have planned - JB4, Meth and... flash tune?
Extra 'new' JB4 stuff as well?
Car: BMW F10 M5
Default 05-24-2016, 03:07 AM
Its a pre-LCI car right?
Default 05-24-2016, 10:29 AM
No meth for us...we'll convert to E85.
Of course we'll be running all the BMS goodies and a JB4 with BCM.
Correct, non-LCI.
Car: BMW F10 M5
Default 05-25-2016, 12:55 AM
Ok so you will make the leap and get those hard to reach flex connects up and running.
Sounds interesting!
Default 06-13-2016, 07:34 AM
Yes, we plan on experimenting with the flex connects.
Here's an update. The new BMS goodies have been installed and are up and running. They include the JB4 Stage 2, BCM, intakes, and charge pipes.
We have now dropped about 1/2 second off our 40-90 time with these mods. I'm sure we could do much better, even on 91 but we have maxed out our trims so we'll need to move on to additional fueling and the flex connects.
Name:  BMS goodies installed.jpg
steeve13m steeve13m is offline
Car: 13 M5 DCT
Default 06-13-2016, 08:34 AM
whats the max boost you are targeting and you are using map6 custom map?
2019 Marina Bay Blue M5 Competition, HRE FF04 21",BMC filters, 5% Window tints,Clear protection film,Escort Passport MAX,zw5,Sprint Booster.
2004 Lamborghini Gallardo -Manual- Giallo Midas Pearl Yellow- Modified Intake, Exhaust, Tuning, Carbon parts, HRE wheels, Sound system, +
Default 06-13-2016, 09:44 AM
We've run map 2, 3, and 6.
Map 3 is fine but trims are high. (Targets 18psi)
Map 2 ran lean due to fueling and trims being maxed out. (Targets 22psi)
We also ran map 6 and targeted 20psi, but again ran lean due to trims maxed out. So for now we'll leave it on map 3 until we get the fueling dialed in.
Car: 13 M5 DCT
Default 06-13-2016, 11:03 AM
The max psi Terry ran was 30psi making 770whp with 100% meth+96octane fuel.....how far are you aiming in terms of power?
Default 06-13-2016, 11:41 AM
850+
It'll be getting turbos, clutch, fueling.....
Car: 13 M5 DCT
Default 06-13-2016, 12:01 PM
Help us understand E85 vs 100%meth...pros/cons etc...and whats involved with conversion to e85
Newguy123's Avatar
Car: 12' 135i
Default 06-13-2016, 12:51 PM
850+
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Msizzle Msizzle is offline
Car: F12 M6
Default 06-13-2016, 04:21 PM
im also curious about the full e85, will you need new injectors/fuel pump like with other cars? And also will jb4 be capable of requesting the additional volume of fuel needed with e85 without a backend flash?
allmotor_2000 allmotor_2000 is offline
Car: 2014 F10 M5 CP Frozen Grey
Default 06-13-2016, 11:02 PM
Why did you install the charge pipes if you don't plan to run meth?
Very interested in what solution you may have for raising fuel delivery. Keep in mind you can run 22psi without fueling issues if flashed. The limits you see now are not the fuel system per se but rather the targets the DME thinks vs reality.
sA x sKy sA x sKy is offline
Car: 2011 E92 335xi
Default 06-14-2016, 05:20 AM
Not sure if its the same on the S63, but all the other BMW turbo engines if boosted, usually result in the stock charge pipe cracking.
AWE Non-Res Exhaust | AWE CF Intake | AWE ColdFront | ER DP | ER Chargepipes | JB4 Stage 3 | Custom SS Methanol | Swift Springs | TPG/DSS 1200hp Axles | Dodson Superstock DCT Clutch | PURE Stage 2 Hi-Flo
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 06-14-2016, 05:33 AM
You will run out of fueling far earlier on E85.
Default 06-14-2016, 07:41 AM
We are well aware of the limitations.
We have the CP's for testing and development purposes.
Correct...it's the trims, as stated.
For full E85...you'll most likely need a flash. We'll have to see how it goes.
Correct.
CJ2 CJ2 is offline
Car: 335i F30
Default 06-15-2016, 09:05 AM
I think this is the thread I've been waiting for.
2019 F90 M5 | JB4 | BMS Elite Intakes | E30
Goodbye old friend - 2013 F10 M5 | PS2 | JB4+BCM | Bootmod3 | BMS Intake | BMS CP's | ER **'s | SSP Spec-R | Meth
Goodbye old friend - 2012 F30 335i | PURE stage 2 turbo | JB4 | BMS intake | ER down pipe | ER charge pipe | ER FMIC | E60 | Meth
Car: BMW F10 M5
Default 06-23-2016, 03:25 AM
Up-dates Steve?
cjrdriven cjrdriven is offline
Car: 2014 BMW M5
Default 06-24-2016, 02:38 PM
Many eyes watching this one.
Default 06-25-2016, 07:00 AM
Not yet, we've been so busy with the S55 stuff we haven't had time to spend on the S63.
Default 07-29-2016, 11:08 AM
We had to put in 3 gallons of E85 to get our octane up enough so our timing didn't tank. No surprise but we are pretty maxed out on fueling at this time.
Stage 1 fuel system upgrade design is about completed and we should have a few prototypes back in a couple weeks to begin testing.
Car: 13 M5 DCT
Default 07-29-2016, 11:18 AM
Steve FYI
Initially map2 ran lean on my non-CP car...although the CP cars run richer on map2 and have ideal a/f
I upgraded to the new JB4 1.5 version firmware and latest July2016 BMW software(all modules) and the car has proper a/f ratios on map2 now.... (no aftermarket ECU flash needed to run map2)
Default 07-29-2016, 01:57 PM
Thanks, we're already running 1.5v but will start working on a new firmware version pretty soon.
We haven't verified the BMW software is the latest but will as the car was just recently in the dealership.
