djcarbon djcarbon is offline
Car: BMW 320i
Default Round 2 of the N54 Engine Swap - Radiator and Intercooler Assembly - 10-29-2018, 07:24 AM
I believe I can safely assume that I do not have the mounting fixtures for the stock N54 Radiator and intercooler as my E90 never had an intercooler being NA. What part numbers would I need to reconstruct the N54 radiator and intercooler assembly?
So far I'm thinking:
Intercooler Mounting:
BMW Sealing - Genuine BMW 17517545367
BMW Sealing Tape - Genuine BMW 17117793752
BMW Cover Module Carrier - Genuine BMW 17117527481
BMW Bracket Frame - Genuine BMW 17117521783
BMW Spring Clip - Genuine BMW 17517798485
Radiator Mounting:
BMW Radiator Adjustment Screw - Genuine BMW 17117529497
BMW Rubber Mounting - Genuine BMW 17427553777
BMW Radiator Carrier Left (M3) - Genuine BMW 17107524912
BMW Radiator Carrier Right - Genuine BMW 17107524914
BMW Sealing Module Carrier - Genuine BMW 17117521121
BMW Rubber Mounting (328i 335i X1 M3) - Genuine BMW 17117805310
BMW Lower Cooler Bracket - Genuine BMW 17117591647
BMW Bracket F.Radiator - Genuine BMW 17117590119
Am I missing anything? I have the screws and quantities also included in my list but I'm just really trying to confirm that with the above parts I'd be able to mount the radiator and intercooler for a 2007 N54/335i manual engine into an E90 engine bay.
JuniorB JuniorB is offline
Car: 2007 e60 5 series
Default 11-07-2018, 03:35 AM
The the radiators have nothing to do with the mounting the intercooler. Unless your using all turbo trim and plastic, mounting an intercooler will be custom.
Car: BMW 320i
Default 11-08-2018, 04:32 AM
Gee. I wish I knew this before I dropped $900 for a nose clip. Lmao.
Default 11-13-2018, 03:19 AM
I looked at real oem for everything I needed for this. My cars are both e60,,and 6mths of each other. The n54 car was xi, so this is were the big differences are. I found that the awd components are the only parts that are not interchangeable, everything else is the same. The front struts, spindles, and hubs are also xi specific.
Car: BMW 320i
Default 11-13-2018, 06:45 AM
