durty sexn55 durty sexn55 is offline
Car: n55
Default N55 help codes and ses light on - 08-12-2017, 10:14 PM
Getting this code and ses, anyone here can help me out
p3202
P0171
P0073
My car is a n55 FB0 stage 2 fuel pump
2011 E82,n55 ,6mt
Stage 3+ Clutch and alumni fly wheel
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Jb4 , fuel flex wire and Bluetooth connection
New water pump and thermostat
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
Ecs Lightweight Front and rear Brake Rotors brake pads
New o2 sensor
New transmission oil MTL red line
Motor oil MoTul 8100
Default 08-13-2017, 10:10 AM
Read codes via JB4.
Car: n55
Default 08-13-2017, 11:53 AM
I did I was getting 2Ef2 ses light at the same time , turning the car off and on light goes away now i move c#5 to c#1 spark plug cars is running good still getting code on my scanner p3203 p0171 I think the Car is running lean !!!
2011 E82,n55 ,6mt
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
New o2 sensor
Car: n55
Default Map 6 - 08-13-2017, 12:00 PM
3 gear 2500 rpm to 5700 93 and e85 e40
2011 E82,n55 ,6mt
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
New o2 sensor
Default 08-13-2017, 02:56 PM
Making no boost... Blue solenoid harness loose?
Car: n55
Default 08-13-2017, 04:11 PM
Just check all the connection and the vacuum lines they look fine
2011 E82,n55 ,6mt
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
New o2 sensor
Car: n55
Default 3 gear up to 4 - 08-13-2017, 04:58 PM
I did another log on 3 gear and a little bit on 4 now is getting almost to 18 psi thank you
2011 E82,n55 ,6mt
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
New o2 sensor
Default 08-14-2017, 10:46 AM
Looks pretty good...turbo is maxed out and has nothing left. Time to upgrade.
Car: n55
Default 08-14-2017, 11:22 AM
Thanks Steve , for some reason Wheni run the scanner instill get the p3202 p0171 any idea why ? I have a new boost sensor and map sensor on it and still getting the same code and car is running lean !!
2011 E82,n55 ,6mt
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
New o2 sensor
Default 08-14-2017, 12:11 PM
What is the description of those?
Car: n55
Default 08-14-2017, 07:15 PM
p0171 i have bad gasket on my exhaust and is running lean on bank 1
p3202 pt can communication fault :can bus off or can bus faulty .....
2011 E82,n55 ,6mt
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
New o2 sensor
Default 08-15-2017, 12:40 PM
Have you checked your can wires to verify they are clean, aren't shorting out on anything, and the JB4 has a good connection?
Car: n55
Default 08-17-2017, 07:42 PM
Yes jb4 hab good connection and I never check my can wires before !!! Where is the can locate at ?
2011 E82,n55 ,6mt
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
New o2 sensor
Default 08-18-2017, 06:20 AM
Those are the brown and green wires you connect to the stock wires in the DME box (that there is no DME in )
Car: n55
Default 08-18-2017, 07:55 AM
I will check that today , now waiting on my stage 2 pure
2011 E82,n55 ,6mt
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
New o2 sensor
Default 08-20-2017, 03:48 PM
m5james's Avatar
m5james m5james is offline
Default 09-11-2018, 09:52 AM
Bump for update since I got the P3202 last night myself using Carista. It's a rare code since I'm finding little info on Google searches. JB4 wouldn't connect via my tablet or phone to clear codes, hoping for better luck this morning.
