Car: 2013 135i
Help N55 E series -
09-21-2017, 04:31 PM
Reason: Forgot details
09-21-2017, 05:39 PM
You'll have to get the code description and use that to diagnose what is wrong with the car. It's not in my N55 code listing, maybe a valvetronic issue based on the first 3 digits? Could be an O2 sensor also as the AFR reading is stuck in open loop.
Car: 2013 135i
09-21-2017, 09:01 PM
I am pretty sure both codes are part of my sensors on the down pipe since it's not stock. But I wanted to know if my logs look alright and why it loses boost sometimes.
09-22-2017, 10:32 AM
The logs look bad, due to AFR being stuck in open loop, which I suspect is the result of the code. It's not a normal code so needs to be addressed.
Car: 2013 135i
11-02-2017, 02:27 PM
The problem with my last logs were a broken O2 sensor which I switched out this week. Can anyone look at my new logs and tell me what is wrong? I get multiple misfires especially in cylinder 5. I also have about 40% E85 mixed with 91 gas, maybe that wasn't such a great idea to do? Thanks in advance!
171102_1308.csv
Car: Bmw 535i - 2011
11-02-2017, 02:50 PM
Is there Any Codes now ?
Car: 2013 135i
11-02-2017, 02:58 PM
Yes it has the missfire codes, I forgot to note them down. One blow off valve tuner code and 5 missfire codes.
11-02-2017, 03:00 PM
Screenshot Them please, it will help in identifying the problem
Car: 2013 135i
11-02-2017, 03:06 PM
The ones I know were: 2C90, 0000, 2EFE, 2F03, 2EF1 .. I will have to check later to make sure. You guys can’t tell by the log?
11-02-2017, 03:12 PM
i cant tell by nothing  , and cant help by a bit  ,
i am just putting you in a path that will make thing's clearer to the bmw guru's when they come to help
wish you the best in solving the problem mate
Car: 2013 135i
11-02-2017, 03:14 PM
Haha okay for sure, thank you! i will try to get the codes out asap.
Car: 2013 135i
11-02-2017, 04:23 PM
My exact codes are as following: 2EFE, 2F03, 2EE1, 2EF3, 2C90 Blow off valve mechanics, 0000, 0000
Only one of them has a description.
11-02-2017, 11:01 PM
Running an old board with newer ISO firmware, I'm assuming the diode on the board has been cut?
If cylinder 5 is consistent...I'd recommend starting there.
Also running pretty rich, probably due to the Dinan tune but that is also causing your HPFP pressures to drop.
Car: 2013 135i
11-09-2017, 07:27 PM
I fixed the problem by changing spark plug #5. I did another log in Map 1 and wanted to see what you guys think, if it looks okay since boost is a little above target. Thanks!
171109_1846.csv
11-09-2017, 11:45 PM
You never confirmed if your diode is cut.
Timing is not good.
A little overboost but not too bad. FF will probably learn down a bit but if the issue continues, may need to do some DB tuning.
