madnking madnking is offline
Car: 2012 335i E92
Default vrsf fmic help - 12-11-2017, 04:33 PM
did you have to cut your turbo side charge air plastic pipe to install included silicone coupler? thanks
bullcitybmmer bullcitybmmer is offline
Car: 2013 335i e92 M Sport
Default 12-12-2017, 01:24 PM
I'm assuming this is an E9X.... but you don't have to cut the actual tube, but you do have to cut off or pry off the little pressed metal bands that hold that little flexible plastic tube onto the turbo side charge pipe (I used a dremel and cutoff wheel). The silicone coupler should marry up nicely after that.
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 12-12-2017, 04:31 PM
There is a spot that you can place a small screw driver into. All you do it twist and it will pop off. Knowing what I know now I would have just removed the pipe to get that tab off. It isn't that hard to remove from the top.
