bullcitybmmer bullcitybmmer is offline
Car: 2013 335i e92 M Sport
Default Log Check after DV+ Install - 10-10-2018, 08:42 AM
Hi Guys, I recently installed the GFB DV+ on my E92 N55 335i, and I'm having some issues with overboosting at low-ish RPMs. After doing some research this morning, I see that I'm not the only one who has had this issue after using the extra "sport" spring that comes with the kit, so I wanted to see if there were any settings I could adjust to tone this down that didn't involve taking it back apart.
I haven't been able to get to my normal E85 station, so this is straight 93 octane.
Mods:
BMS intake, VRSF 5" intercooler, charge pipe, turbo outlet pipe, ******* **, GFB DV+ with sport spring, JB4 + Pump BEF
Default 10-10-2018, 10:20 AM
Set duty bias to 50 across the board an lower FF to 40 and get another log for me.
Default 10-10-2018, 11:32 AM
Yes sir. New log attached.
Default 10-10-2018, 11:39 AM
From 4500 RPM and up raise duty bias +10.
Raise FF to 65 and get another log.
Looks much better no more boost spike, now I'm getting you closer to target boost through the rev range.
Martin.328 Martin.328 is offline
Car: 16 328
Default 10-10-2018, 03:43 PM
what about changing default WG position ? wouldn't that help in this situation ?
Default 10-11-2018, 07:15 AM
Here's a quick log with the requested changes. It looks, and feels, a lot better.
