suspenceful's Avatar
Car: 2008 BSM 135i
Default Doc Race Intake Manifold Installation and Dyno Results! - 08-14-2018, 08:55 AM
Well, I installed my Doc Race intake manifold on Saturday!
I put together a very detailed write-up with a required parts list, DIY installation and dyno data. Check it out now:
http://my1series.com/2018/08/14/doc-...-dyno-results/
For a brief overview, here are some photos and a video.
Here's a graph I overlaid with the stock manifold vs Doc Race manifold. It favors the stock manifold for ambient temperature and spool RPM, but gives you an idea of the power it picks up in the midrange. This is good power under the curve. +49whp and +47wtq at 5500 RPMs. I will eventually go back to the dyno and do a 29psi pull in 70*F weather starting at 2000 RPMs with the Doc Race intake manifold for a more apples-to-apples comparison.
🚀 My 750HP 135i build: my1series.com
🔧 My budget 335i build: bmw335i.com
📷 Follow me on Instagram: instagram.com/jakespence
🎬 Watch me on YouTube: youtube.com/jakespence135
🌟 Support me on Patreon: patreon.com/jake_spence
🏁 Shop BMW merchandise: bimmerstreet.com
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 08-14-2018, 11:39 AM
You rock !!
Do more with less !
Default 08-14-2018, 07:03 PM
Nice! Have a clean before after run at the same boost level so we can see what the manifold added?
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 08-15-2018, 01:14 AM
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Car: 2008 BSM 135i
Default 08-15-2018, 08:10 AM
I don't have an apples-to-apples comparison unfortunately. I'll be going back on a 70*F day and doing some pulls at 29psi from 2K RPM. That should give me a good idea of power gained with the manifold.
Magnusk77's Avatar
Magnusk77 Magnusk77 is offline
Car: BMW 135i
Default 12-05-2018, 06:29 AM
did you ever go back and do this?
2009 BMW 135i - Monaco Blue
Car: 2008 BSM 135i
Default 12-05-2018, 07:01 AM
No, I didn't. Hoping to go back in the spring, car is currently hibernating right now.
rcpro88 rcpro88 is offline
Car: 535i
Default 12-05-2018, 07:50 AM
Is that intake manifold cast aluminium? They would obviously machine the part afterwards too.
DON'T buy VRSF D.Ps or inlets! FBO, E85 Walbro 450, xHP trans flash
Car: 2008 BSM 135i
Default 12-05-2018, 08:30 AM
Yes, it's cast (I'm assuming aluminum). It has been machined after casting.
Six Pot's Avatar
Six Pot Six Pot is offline
Default 12-05-2018, 04:34 PM
Can’t wait to Dyno mine. Still not a fan of the fuel rail setup...
2011 BMW VO 1M (Currently in pieces for New Build!)
==OLD SETUP==
ViE 3884 | PR | JB4 | EOS Billet Fuel / Manifold | Seibon Hood | Spec Twin | 900IC | Slek Lip / Diffuser | EC7 Wheels | KW HAS | Maddad + GTHaus | P3 | ViE Can
08 335Ci's Avatar
08 335Ci 08 335Ci is offline
Car: 08 335Ci
Default 12-06-2018, 08:52 AM
Without a before dyno run, this is basically a sales blurb.
'10 E92 335 M Sport, JB-4 G5 ISO, 3" CPE Charge pipe, WMI w/dual CM 5 nozzles, 3.5 Tmap, ARM Relocated Inlets (don't do it), VSRF Outlet, BEF, Front Strut Brace, SS brake lines, Drilled and Slotted Rotors, Anti-lag, OCC. Escort Max 360
Totaled by a careless driver:
'08 E92 335, M sport option
Magnusk77's Avatar
Car: BMW 135i
Default 12-13-2018, 06:56 AM
Yeah I'm interested but hestitant. Without apples to apples comparison it's hard to justify it for unknown performance gains. Turbo cars can be very deceiving if the conditions arnt the same as far as dynos go. Cosmetically it looks amazing though, no doubt.
Car: 2013 Genesis Coupe
Default 12-13-2018, 11:52 AM
Originally Posted by Six Pot
Canít wait to Dyno mine. Still not a fan of the fuel rail setup...
Wow your turbo is clocked pretty aggressively
I can't justify the purchase either
Six Pot's Avatar
Default 12-13-2018, 11:57 AM
We have fixed the clocking but now it has caused all kinds of drain location issues. Having to fab up a metal drain pipe
==OLD SETUP==
Default 12-13-2018, 12:00 PM
What kind of drain issues?
Six Pot's Avatar
Default 12-13-2018, 12:04 PM
10AN fitting will not fit at all now so we moved back to 5/8 line just to start it. The big problem is how close the line is to all the hot parts and touching, line will not survive for 10 minutes. So we are still playing around but I think the answer is to fab a 5/8 metal line to avoid issues long term
==OLD SETUP==
Default 12-13-2018, 12:09 PM
How are you routing oil drain line?
Six Pot's Avatar
Default 12-13-2018, 12:18 PM
When it was overclocked we had a straight down 10AN to 10AN to the block utilizing a Vader-like block converter. Post reclock @ 12 we no longer can route against the block so we literally have to go down then curve threw the manifold to get to the drain which now creates the issue at hand. So the only option we can think of is a metal line to mitigate it.
==OLD SETUP==
Default 12-13-2018, 12:42 PM
Hmm I had to play with mine too, I'm putting my car back together, should have everything by now next week I'll send you photos. Reaching out to Jon wouldn't hurt either bro
Six Pot's Avatar
Default 12-13-2018, 01:06 PM
Honestly I am not here to knock Jon but I have sent a few emails... Also there are three variables here: One this is a one off kit to accommodate a 1.0 AR hot side, Two its a 1M which could factor in ... maybe/maybe not, Third his how the kit was built especially how it splits out the screamer since the front dumps near the IC and doesn't route back near the rear screamer like most other kits. I have had to route a lot of custom lines to get the kit to work.
So not to hijack this thread but yeah let me know if you have advice here :-)
==OLD SETUP==
Default 12-13-2018, 01:16 PM
Did he respond to you at all? On the front dump tube you should be able to mount it to the rear, I was able to do that because mounting it up front by the fmic didn't make sense to me and it cleared. Multiple fabricators and the kit not being mass produced will create a small margin of error, nonetheless your happiness as a customer is what matters the most.
Six Pot's Avatar
Default 12-13-2018, 01:21 PM
Not yet, I can try again....
Honestly I am not mad, I knew going into this it was likely not going to be a 100% bolt on experience. We did try to turn the front screamer to the rear, it just wont work on my side so we are fabbing a new one to dump in a better location. The biggest concern is the impossible oil return location without having horrible clocking.
==OLD SETUP==
Default 12-13-2018, 01:31 PM
You've tried twisting and turning the dump tube as a you try to place it to the rear? What's getting in the way? I'd email him or send him a text through messenger
Six Pot's Avatar
Default 12-13-2018, 01:35 PM
Ill need to take a pic, WG clocking + Front Screamer clocking just doesn't clear the manifold.
==OLD SETUP==
