zcchen zcchen is offline
Car: BMW 1M
Default M Button in 1M after JB4 and BEF - 10-22-2018, 12:29 AM
Does anyone know if the M button/Sport Mode on the 1M is still relevant after JB4 with BEF?
I believe when stock, the M mode/Sport mode does the following:
1. More aggressive throttle map
2. Temporary over-boost in the mid-range rpm for extra torue
After JB4 and BEF, I still feel the more aggressive throttle mapping in M mode but I have no idea whether there is over-boost. Curious to find out.
Also, is it possible to alter the throttle mapping in M mode only? If so, how?
Default 10-22-2018, 08:11 AM
All those factory stuff will remain. Get a log so we can see how the car is doing. Target boost will always be the same in each map regardless of sport mode etc.
Car: BMW 1M
Default 10-23-2018, 07:37 PM
Here is the log using normal mode. I guess I need to find a time to test back to back normal vs M mode.
Six Pot's Avatar
Six Pot Six Pot is offline
Default 10-25-2018, 07:01 AM
From my experience and logging so far it seems that the throttle response stays but I don't see overboosting. I would assume that is due to the JB4 overriding whatever logic the DME is trying to send.
2011 BMW VO 1M (Currently in pieces for New Build!)
==OLD SETUP==
ViE 3884 | PR | JB4 | EOS Billet Fuel / Manifold | Seibon Hood | Spec Twin | 900IC | Slek Lip / Diffuser | EC7 Wheels | KW HAS | Maddad + GTHaus | P3 | ViE Can
martymil's Avatar
martymil martymil is offline
The Backyard Mechanic
Car: BMW 1 Series M
Default 12-20-2018, 01:17 AM
Digging up this thread
No the m button doesn't work when using a jb4 and bef
Six Pot's Avatar
Default 12-20-2018, 03:58 PM
The throttle response does, overboosting doesnt
==OLD SETUP==
Default 12-20-2018, 04:41 PM
The basic issue there is the JB4 map2 runs MORE boost than the factory over boost option. So you won't notice it as much.
martymil's Avatar
Car: BMW 1 Series M
Default 12-20-2018, 05:02 PM
Doesnt work with the Aussie models, absolutely no difference unlike when running mhd the car turns and feels way more aggressive when pressed
Six Pot's Avatar
Default 04-22-2019, 07:50 AM
Directed to Payam and team, any way to make it change maps on the fly? IE: Non M = 3 , M Mode = 5?
==OLD SETUP==
Default 04-22-2019, 09:30 AM
In theory we could but there are so few M models out there, not sure it's worth it, considering how easy it is to change maps in dash.
