Car: All of 'em
04-18-2018, 03:23 PM
Originally Posted by bloxsom
Its the only USB in the computer lol
Don't take any offense! Sometimes when we are elbow deep in a headache like this, the little things are overlooked. I feel your pain right now brother.
Can you try a different laptop? Just to rule out some issue there.
I've never ONCE had this happen, but I suppose it's possible that your firmware update failed at such a time that the jb4 has no software to be able to support serial communications anymore. Terry's a smart guy though, I'm not sure that he would allow that problem to exist.
I don't know the inner-workings of the JB4, that's all proprietary information.
From a business standpoint, you will run yourself into the ground assuming responsibility for fixing the product. Don't take it personally, we didn't make the JB4 and we don't know with certainty how they work. I would remove it, and ship it back to Burger to have it tested/repaired (if necessary) and start again.
I've never had a JB4 fail right in front of me, but I have had a couple that showed up not working the way they were supposed to, and Burger has been very good about helping.
Just be glad you're not dealing with an underboost isolated to one bank. That's a headache.
Car: M5
04-18-2018, 03:27 PM
So looking at my harness with the BCM. The BCM has the red wire for power. But how does the JB4 get power? I have 5.0v at pin. #24
Car: All of 'em
04-18-2018, 03:33 PM
I'm sorry. I gave you some mis-information. It looks like this Jb4 takes power from the TMAP signal.
Car: M5
I have another one on the shelf for the TU. Im going to see if I can talk to that one.
Car: All of 'em
04-18-2018, 03:37 PM
Good idea. If you can communicate to that one, I would begin taking the JB4 out of the car to send back to Burger for testing. They may not even charge you, Terry's a pretty good guy. They might be able to just flash program the best firmware on the bench and send it right back.
04-18-2018, 04:19 PM
Knowing this is a BETA product that is no longer supported this is what the customer wanted.
3a. POWER and GND installed in the 30a fuse, and shock tower bolt. (checked GND and PWR with DVOM. All ok at this time.
The frustrating part is that I have been doing this for 3 days now I even tried to upload the software prior to calling the customer in. EG:
Supplied power and GND to the JB4 (as if key on) and then Connected it VIA USB to the computer. I got nothing. I contacted Burger and they said install it and then update. We still have the same problem, thus my concern from 3 days ago.
My though is the same as yours. If its key on and usb is connected. Then I should be able to update the JB4.
(note: I also tried the app on my phone to connect and nothing)
A little confused, there is no power or ground connection for the JB4 itself. The optional BCM has connections but no need to bother with that yet.
JB4 attaches to TMAP sensors, then CANbus wires in the DME box.If using a JB4 mobile adapter it attaches to one of the red wires in the JB4 harness, and if using a BMS data cable it just plugs in to the laptop.
Install photos?
Car: M5
04-18-2018, 05:39 PM
I took it all out to give it back to the customer they needed it for work.
I have done quite a few installs. So im pretty confident on the installation. (NOTE: the red and black power wires are for the BCM)
What I did do, is install another JB4 board to the harness and it connected it.
(i used the app on my phone this time VIA Cable)
-It connected!
then
-"Error, Unable to initiate data stream from JB4. Please try reading codes or connecting again"
NOTE: it did show map 1 selected.
So I uploaded the software to the new jb4 board. for the "S63"
It once again, loaded twice, the first time was an error. Second time, it said successful.
THEN - i could no longer connect to the JB4.
Did i brick both JB4s with the "s63 Software"
04-18-2018, 07:20 PM
Did you try disconnecting CANbus wires leaving only TMAPs attached?
If you want to send the boards in we can always reflash them here, with the correct software for an S63.
Car: M5
04-19-2018, 08:17 AM
No I did not. Ill send them both in. Just to the address posted on your site?
Burger Motorsports, Inc.
2235 First St, Suite 122
Simi Valley, California 93065 USA
04-19-2018, 09:13 AM
Correct
Car: M5
04-19-2018, 02:34 PM
You will have them Monday!
04-19-2018, 07:33 PM
OK will get them turned around quickly for you.
Car: 2009 BMW 535i
2013 X5M -
07-13-2018, 11:29 AM
Hopefully somebody can give me a little insight. I’m running Map 3 with E30 but when I did a couple logs yesterday my target did not go past 17 psi (see log below). Does anybody idea what could be going, I thought the target for map 3 is supposed to be 19psi? Also anybody care to share their map 6 settings?
2013 X5M
Modifications: K&N Drop-In Filters | JB4 | Exhaust | xPH Trans Flash | HCP Stage II ECU Flash Tune
07-18-2018, 04:24 AM
Anyone have this issue
JB4 user adjustments corrupted everytime you try to connect?
07-18-2018, 08:37 AM
Is the JB4 firmware and interface on your device updated?
07-18-2018, 09:43 AM
Yes it has
Its on the latest available firmware.
07-31-2018, 03:34 AM
Need some advice on these logs
Map 1 is leaning out
Map 4 is fine
07-31-2018, 09:19 AM
Trims are way high on map4, also. Pump gas?
07-31-2018, 09:46 AM
I7
That was race gas 109 octane.
Running a flash tune as well.
07-31-2018, 09:54 AM
Map 4 is safety map...how can things reading bad there as well?
07-31-2018, 09:59 AM
Means the problem isn't JB4 tuning related, but something with the car itself.
07-31-2018, 10:00 AM
I7
Sounds like the fuel scalars are set wrong in the flash map. Have them fix it. Map4 should have fuel trims at 25 or lower (0%).
07-31-2018, 11:23 AM
Will give a shot
Thank you
07-31-2018, 04:33 PM
Is there a wastegate rattle fix? Mine went from fine one day to REALLY bad :/ I read something likely N54 related since it didn't work but I adjusted Future Use D from 0 up to 99...still rattles. I read something else about steering wheel controls (not controllable via the app) in settings 10, 11 & 12 but they didn't explain how/why, let alone if it's even available on our firmware.
08-01-2018, 03:51 PM
Bump.
Thread Tools |
Display Modes |
