alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default N55 Build Motor - 11-27-2017, 09:01 PM
Hello folks!
I thought it's a good time to share my build. We have here probably the first N55 full build motor. The project still in the works. All the work has been done by ABR Houston. They have done an amazing job so far. The build motor includes closed deck, ported and polished heads with Ferrea valvetrain.
Here is pic of the small block:
Here is the cylinder heads
Also, I'll be installing Big Boost 3.4 Turbo kit.
The car still Auto for now. I still debating in between upgrading to a full build Propulsive Dynamics AT or DCT swap.
More pictures to come stay tuned
2011 E92 ABR N55 Built Motor | ABR Built 6AT | Big Boost 3.4 Turbo Kit | JB4 + MHD | xPH Stg3 Flash | Fuel-It Stg 3 LPFP | Fuel-it PI Kit | COBB Exhaust | E85 |
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 11-27-2017, 09:03 PM
Wow, sweet stuff man!
Do you mind if I ask you how much this all costed?
Also how are you going to tune the car? MHD? Not sure if the knock sensor tables need to be readjusted too because of the different alloy in the pistons and the closed deck nature of the block.
edit I see youre not F series so it must be mhd or something else.
Mods: Stock for now
Default 11-27-2017, 09:21 PM
Ewww...always nice to see shiny parts! Looks good thus far!
Forged pistons, rods, and crank?
DCT swap, M4 flywheel, and SSP clutches.
alexis485's Avatar
Car: 2011 BMW E92
Default 11-27-2017, 09:26 PM
Also how are you going to tune the car? BM3? Not sure if the knock sensor tables need to be readjusted too because of the different alloy in the pistons and the closed deck nature of the block.
All I can say it ain't cheap!
I have E-series so, I'll be using JB4 and MHD BEF.
I thought about the knock tables too. I guess we will know more about that during the tuning process.
Default 11-27-2017, 09:28 PM
SO excited... i heard about this from ABR several months ago. Cant wait to see #'s
alexis485's Avatar
Car: 2011 BMW E92
Default 11-27-2017, 09:35 PM
Thanks Steve!
Everything is forged!
Actually, ABR found that the M235's and M2's already have forged crankshaft compared to the regular N55's.
Lowon's Avatar
Car: Bmw M2
Default 11-27-2017, 09:41 PM
Originally Posted by alexis485
Hello folks!
Attachment 69498
Attachment 69499
Attachment 69500
Lol tell me about it, I built alot of EJ motors in subarus and each time they costed almost $20k CAD for head work, internals, porting, labour, parts, etc.
Mods: Stock for now
JETmn JETmn is offline
Car: 2011 335xi
Default 11-28-2017, 08:15 AM
Awesome! Keep us updated!
bullcitybmmer bullcitybmmer is offline
Car: 2013 335i e92 M Sport
Default 11-28-2017, 10:17 AM
This looks awesome, I'll be following this with interest.
Also- InB4 someone lectures you about just upgrading to an M-model being a better spend of your $$.
Default 11-28-2017, 04:31 PM
i am really interested about the knock table issues. They have stand alone for N54 but not for the N55 yet. I hope you can get this going without getting to radical (although part of me hopes you have to get radical and pull it off )
I know my engine will blow in the next 24 months so will be watching closely. Is the M235/M3 crank plug and play? For a 1K HP set up I was thinking OEM pistons, forged crank and rods, ARP head studs might do the trick.
A few questions if you have time:
1. Did you go with stock compression?
2. Is the new crank plug and play?
3. Did you use new ARP hardware, if so did ABR finish there head studs or what did you do here?
4. What are your power goals?
Seems like with this engine and your trans its going to be a long and exciting ride.
Showtime456's Avatar
Showtime456 Showtime456 is offline
Showtime456
Car: 2014 BMW 640 GC
Default 11-28-2017, 06:27 PM
If you dont mind me asking. What parts are you using?
alexis485's Avatar
Car: 2011 BMW E92
Default 11-29-2017, 05:36 AM
[QUOTE=jturboawd;569684]
QUOTE]
1. Yes, It's stock compression.
2. It's plug'n'play. No modification is need it.
3. That's the most difficult part to get. I've talked to ARP and Raceware ,and they don't want to do it. Apparently, they are geared towards volume production so, N55 studs are no no to them because it's very expensive to produce custom engine studs. The shop was really concert about this too but, they back down after talking to TPG. TPG is running stock heads bolts in their S55 build motor without a problem.
4. My goal is 750 whp for now.
alexis485's Avatar
Car: 2011 BMW E92
Default 11-29-2017, 05:40 AM
So far JE pistons, Manley rods and Ferrea valvetrain.
Showtime456
Default 11-29-2017, 05:44 PM
subscribed!!!!
durty sexn55 durty sexn55 is offline
Car: n55
Default 11-29-2017, 08:18 PM
Suscrito!!!
2011 E82,n55 ,6mt
Stage 3+ Clutch and alumni fly wheel
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Jb4 , fuel flex wire and Bluetooth connection
New water pump and thermostat
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
Ecs Lightweight Front and rear Brake Rotors brake pads
New o2 sensor
New transmission oil MTL red line
Motor oil MoTul 8100
hardparker hardparker is offline
Car: F25
Default 12-02-2017, 09:09 PM
Nice build. Can you elaborate on the deck closure? How was that done? Before and after pics? How about the sleeves? Were they resleeved, or just bored/honed? What kind of bore clearance are you going with on the pistons?
alexis485's Avatar
Car: 2011 BMW E92
Default 12-11-2017, 08:09 AM
I'm sorry but, I never got a notification about your post.
ABR prefer inserts instead of sleeves. Here is the link of their website on the closed deck process and the whole built (BTW, their website shows a N54 but, it's basically the same process on the N55, etc.)
http://www.abrhouston.com/performance-engines/
I'll post before / after picture of the closed deck conversion later.
Mouse Mouse is offline
Car: F30 335i
Default 12-11-2017, 03:42 PM
I still need to stop by ABR. I've heard some really good things about them.
OP:Hope to get to see your build when I stop by. I could use some inspiration.
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 12-11-2017, 06:47 PM
nice, build I wanted to port the head a while ago, but didn't really step into it yet, looking for feedback. are you doing the valve lift support mod too or leaving intake lift stock?
is Ferrera valves necessary I don't see the need without rising RPM limit.
N55 - Doc race 6266.
Default 12-11-2017, 08:24 PM
Subscribed.
alexis485's Avatar
Car: 2011 BMW E92
Default 12-12-2017, 05:52 AM
Sure! They have worked on my car many times. Everytime is top notch work!
It's stock lift. I got the Ferrea valvetrain because I'm hoping for VAC to releases upgraded cams for the N55 in the near future.
Subscribed.
I'll need your help soon.
terryd5150's Avatar
terryd5150 terryd5150 is offline
Car: BMW 335xi
Default 12-17-2017, 09:05 AM
Subbed.
jsgrinst78's Avatar
jsgrinst78 jsgrinst78 is offline
Car: 2014 335i
Default 01-02-2018, 12:42 PM
SUB'd...this thread peaks my interests
2014 F30 335i, M-Sport, 6MT, VMR V801 Wheels, custom exhaust, CTS Turbo Intake, CTS Turbo IC, FTP CP, VRSF **, Turner Motorsport Strut Brace, Bootmod3 Stg 2, 381 who, 429 wtq (waiting for install: GFB DV+) Next: Ohlins R&T, M Performance LSD, M Performance Brake Kit
ahmedmoe's Avatar
ahmedmoe ahmedmoe is offline
Car: F30 335i
Default 01-03-2018, 02:14 AM
subbed! I following a similar route. left my old engine (that I bent a rod) at a garage, should be able to rebuild it, well going to find out if so.
@alexis485 are you planning on changing the cams?
n55.PWG.2012
CobraMarty CobraMarty is offline
Car: BMW
Default 01-05-2018, 03:04 PM
Will the head be ported and flowed?
Hey if you need more info on adding MILVs, let me know.
