ChristopherMcDonnell ChristopherMcDonnell is offline
Car: 2007 E92 335i
Smile E92 335i - New car engine light over 120mph - Logs attached - 12-03-2020, 07:56 AM
Hi Guys
Few questions appreciate any help.
Bought this 335i two weeks ago and often goes from map 2 into map 4 whenever I do a higher speed pull. Doesn't happen in 1st or 2nd. Only top of 3rd or start of 4th on WOT.
Boost is also lower than I would expect for map 2?
Here are the error codes logged on the car
2EF7 characteristic diagram thermostat, controls
2A82 Inlet-Vanos variable cam control test
3100 low boost mode engaged -- CEL displayed
Also, when loading the JB4 desktop app up for the first time I could see third gear was set to 2.0 in settings, however, the log show it going beyond that...
I am of course going to replace the vanos but would appreciate any other feedback on if the logs look ok and the settings are ok?
Car has Jb4 and *****. No other mods.
Log 2: No traction loss - https://***********/u/christopher338/pull-2-3rd-gear
Log 1: https://***********/u/christopher338/pull-1-3rd-gear
Slight traction loss at start over manhole cover -
Also photos attached of settings.
My questions are:
1. I ordered a new Vanos, it will be here in 2 days, is this most likely the engine light issue?
2. My boost is hitting 12-13psi, should it be hitting the 14.5psi in map 2 or is this normal?
3. Why when 3rd gear is set to 2psi does the car still make 12-13 psi?
I've also attached my settings.
I'm doing a trackday on the 19th so would love to get the car running smoothly
Last edited by ChristopherMcDonnell; 12-03-2020 at 07:59 AM.. Reason: Links removed. Fixed.
DeepEddy DeepEddy is offline
Car: E92
Default 12-03-2020, 07:01 PM
tmap should be 0,1or 2 depending on the trap sensor u have installed
and 6-cyl timing settings are wrong that depends on ur dme is it msd80 for i8aos or msd81 for ijeos
Car: E92
Default 12-03-2020, 07:06 PM
Now that I looked again you should really stop where u are and reset everything to default and go from there . Your settings are out of wack
Car: E92
Default 12-03-2020, 07:07 PM
E Series N54 JB4 - N54Tech.com - International Turbo Racing Discussion
Start here there is a pic of default settings .
Car: E92
Default 12-03-2020, 07:12 PM
For starters
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 12-03-2020, 08:25 PM
Your max boost for 3rd was set to 2.0
2011 335d
2013 335is
2018 340i
Car: 2007 E92 335i
Default 12-08-2020, 06:34 PM
DeepEddy
Thank you very much. It seems someone purposely entered random stuff in the JB4! Now that I've read up on it a bit more I'm not sure where anyone came up with these settings.
I started by updating the firmware on the JB4 to the latest version. I then setup everything as in photos you sent. (Thanks!)
I have not set 6 cyl timing yet but will go back and fix at a later point.
Here's my new log: https://***********/u/christopher338...log=0&data=1-4
In regards to the below:
Is that thermostat or can it be a multitude of things?
I have smoke coming from the exhausts (albeit a small amount) constantly (white), and it does have a sweet smell). I presume head gasket in N54 would be pretty uncommon, what else could it be?
Car: 2007 E92 335i
Default 12-08-2020, 09:06 PM
Also I must add I’ve had no oil consumption in the 2-3k miles I’ve done so far.
