justanotherm2c justanotherm2c is offline
Car: M2C '21
Default JB4 shows nothing - 04-16-2022, 05:05 PM
Hey there.
After installation my JB4 on M2C '21 (iOS App, OS version is 15.4.1 + carplay enabled if it matters somehow) not showing any info at "Display page". Sometimes it show boost and something else, but nit RPM, sometimes only RMP.
Also I have Bit6:Passive Delete option enabled (Im outside of USA as you can see by my English language level ), but today "check engine" error comes. I have down*pipes and im 99% sure thats the reason.
Logs shows nothing when reading, so I can't delete it as well. Also when I change maps, if i choose 1 for example, sometimes it still 0 and need to re-choose again.
Can someone please guide me what we did wrong and where should we take a look?
Thanks in advance.
RVA_N55_Fan RVA_N55_Fan is offline
Car: 2014 435i
Default 04-16-2022, 06:18 PM
Did the jb4 log correctly from a laptop connection? If so, I'd email the mobile support folks. They are good about responding quickly
2016 435i M-Sport EWG MPPK Manual 6, BMS Map 6 BEF-PS2-Race, Pure Stage 2 turbo, Spool-FX150 HPFP, Walbro 535 LPFP, BMS Intake, BMS FMIC, BMS BOV, 3.5 TMAP, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMS Clutch Stop, BMS Diff Bracket, BMS Wheel Spacers, BMW SSK, BMW Track Package
Car: M2C '21
Default 04-17-2022, 06:43 AM
Thank you for your answer! I thin the issue is odb2, will try to check tomorrow.
Default 04-17-2022, 11:34 AM
Also grab latest firmware update.
Car: M2C '21
Default 04-17-2022, 01:27 PM
Somehow I can't reply to your message, site keep saying i should have 5 posts to post links (idk where is any link), but anyway,
Thanks for your answer Terry! Should I update from the iOS app?
Car: M2C '21
Default 04-18-2022, 04:27 AM
Ok, finally it looks working!
Installed latest firmware update and disconnected my car alarm (because it use CANbus), and everything looks fine now.
Hope it will helps someone
Default 04-18-2022, 11:10 AM
OK makes sense, anything else on CANbus could conflict if using same address.
Car: M2C '21
Default 04-18-2022, 12:28 PM
But it always will use sae address right? I mean i can't connect JB4 to other one?
Sorry Im not a tech guy
also still can't use "Quote" button...
Default 04-18-2022, 04:36 PM
If they conflict then they can't be used together.
Car: M2C '21
Default 04-19-2022, 09:10 AM
Understood. Thanks a lot Terry
AndrewCash AndrewCash is offline
Car: Swift
Default 07-09-2022, 02:04 AM
Everything looks good.
Stay happy always.
